- Code: Select all
exec.Callbutton(125);
in the M99998.txt startup macro. My tests show that the problem occures only when there's no file loaded. (When you press close file then the Contents\Empty.txt is loaded, so that's not the same as if no file is loaded.)
Thank you for the report.
