IF
Discussions and examples of Parametric programming in UCCNC
IF
Postby claudio » Wed Sep 26, 2018 7:43 am
I have problem with this command:
N155 IF[#15 LT #6]GOTO115
I use this in a editor for Fanuc language
there is a solution also UCCNC?
There is a manual with the list of logical commands?
How write comments in the program?
Thank's
Claudio
claudio
Re: IF
Postby dezsoe » Wed Sep 26, 2018 9:22 am
You can write comments in (brackets).
UCCNC has no conditional statements and logical expressions.
Re: IF
Postby claudio » Wed Sep 26, 2018 3:20 pm
Thank's
claudio
Re: IF
Postby cncdrive » Sun Apr 23, 2023 5:08 pm
There will be in the next UCCNC release. IF, GOTO, WHILE.
The documentation will describe it.
Re: IF
Postby Coyote94 » Wed Apr 26, 2023 8:38 pm
cncdrive wrote:There will be in the next UCCNC release. IF, GOTO, WHILE.
Any release date ?
Coyote94
Re: IF
Postby cncdrive » Tue Jun 06, 2023 8:45 pm
Not yet, but we doing the last adjustments and fine tunings currently.
Re: IF
Postby Battwell » Mon Jun 26, 2023 12:43 pm
:-) that will make things nicer.
Re: IF
Postby El Ventu » Sun Sep 22, 2024 6:52 am
cncdrive wrote:Not yet, but we doing the last adjustments and fine tunings currently.
That's awesome!
I'm converting a small milling machine with your AXBB-E and initially I was thinking to use Mach3 since I previously used it.
In last days a friend suggested me to take a look to UCCNC and I loved it.
I'm a lathe machinist for 20+years now, and I'm usually program with parametric.
Having the possibility to use logic like IF WHILE OR THEN ELSE is awesome!
El Ventu
Return to Parametric Programming
