AXBB-E and Mach 4 not linking
Posted: Sun Feb 25, 2024 7:26 pm
Good morning,
Ive recently purchased an AXBB-E as I have not been overly happy with my SmoothStepper. I purchased with the intent to run on Mach 4 as i currently own that software and then try UCCNC and possibly upgrade to that if I liked it better. I did not realize that it does not link in demo mode and allow you to test it so I cant pull the trigger on that until I can at least get it to work with what I own. Ive gone through all the installation steps and I cannot get this unit to Link to Mach 4. No blue light, no recognition, no passing go. Funnily enough I have been able to get it to work with a demo of mach 3, multi axis movement, multiple input recognition.
Specs:
Windows 10 Home-Brand new install(Tried 11 as well)
Intel(R) Ethernet Connection (2) I219-LM
12v Power Supply-Check
24v Power Supply-Check
Mach 3-3.043
Mach 4.2.0.5036(Ive tried others as well)
Proper Ethernet Cable-Check
Is there a recommended version of mach 4, Is there a known issue that im missing with my hardware/software configuration, any help would greatly appreciated.
Specs:
Mach 3-3.043
