Beginner question about setting backoff distance in Mach3
Posted: Thu Apr 28, 2022 11:47 am
Greetings from India
I am using a UC100 with Mach3 on Windows 7. Currently when i click the ref all home button, the arm moves till it hits the limit switch and then moves forward 5mm. How can i change this backoff distance to 2mm?
Please suggest.
I read somewhere that you need to edit the vb script in the ref all home button. Is that true? If yes, what should i include in the code?
Thank you
Please suggest.
Thank you
