Beginner question about setting backoff distance in Mach3
Postby sanj1505in » Thu Apr 28, 2022 11:47 am
Greetings from India
I am using a UC100 with Mach3 on Windows 7. Currently when i click the ref all home button, the arm moves till it hits the limit switch and then moves forward 5mm. How can i change this backoff distance to 2mm?
Please suggest.
I read somewhere that you need to edit the vb script in the ref all home button. Is that true? If yes, what should i include in the code?
Thank you
sanj1505in
Re: Beginner question about setting backoff distance in Mach
Postby ger21 » Thu Apr 28, 2022 1:27 pm
Mach3 does not have a backoff setting. It backs off until the switch opens.
Postby sanj1505in » Thu Apr 28, 2022 2:06 pm
Can I maybe reduce the speed of the motor once the limit switch is triggered? A previous installation of mine did not have this big of a movement after hitting the limit switch
sanj1505in
Postby Dazp1976 » Thu Apr 28, 2022 6:45 pm
sanj1505in wrote:Greetings from India
Please suggest.
Thank you
Fig, 5.6.1 on page 5-30 (more or less) of the Mach operating manual.
Homing/limits, in same tab as ports/pins and motor tuning.
There's a "back off" and a speed setting in there.
Don't know what they actually do but have a fiddle with it and see.
Dazp1976
Postby ger21 » Fri Apr 29, 2022 11:30 am
No, there is not. There's a Home Offset, but no "backoff".
Postby Dazp1976 » Fri Apr 29, 2022 4:57 pm
Ah. "off" is offet, not a back "off". Gotcha.
Never tried it.
Dazp1976
Return to Mach3/4 Discussions
