Backlash issues
Backlash issues
Postby tipos » Sat Nov 06, 2021 7:09 pm
Hello,
i have a little problem. Backlash dont work on X axis however Y and Z is working.
Any ideas?
tipos
Re: Backlash issues
Postby tipos » Sun Nov 07, 2021 6:24 am
Working in Mach 4 with UC100
In Mach 3 backlash working properly. However i used old ver 2.5 and jogging not working. So i upgrade to mach 4.
tipos
Re: Backlash issues
Postby cncdrive » Tue Nov 09, 2021 2:47 pm
We will debug this, but will need some time, I reported the issue to my Mach4 plugin developer collegue.
Re: Backlash issues
Postby tipos » Thu Nov 11, 2021 3:00 pm
Ok, thank you.
Any news?
If you get some info please post info here. If somebody has same issues.
tipos
Re: Backlash issues
Postby cncdrive » Thu Nov 11, 2021 4:39 pm
No news, as I wrote we will need some time to check this out.
Re: Backlash issues
Postby tipos » Sat Feb 05, 2022 6:17 pm
Hello,
do you have some tips where could be problem?
Thank you
tipos
Re: Backlash issues
Postby tipos » Tue Feb 22, 2022 8:05 am
it's been a while, so i tested a few things.
-First of all, i bought a motion controller (driver was connected to uc100 directly).
Now everything is connected through a mainboard (czech site: https://www.caucau.cz/elektronika/profi4-zakladni-deska)
Pins are a little bit different. P2 with P3 are used to relay. A table is on that site.
-I found on newfangled's site url with different versions of mach4, so i tested the newiest one, the oldiest one and something between thoose one.
-Of course i tried find help on their helpdesk, they respond with i must contact uc100 developer.
-All test's I did on pc and personal notebook with different systems.
Maybe i can try a different version of firmware uc100, but i cant find anything.
tipos
Re: Backlash issues
Postby cncdrive » Wed Feb 23, 2022 1:57 am
Unfortunately the Mach developers changed things in their plugin interface which made our plugins not to work properly with the newest versions of Mach4.
My collegues are working on resolving this issue, but it takes time, because lots of things have been changed.
To fix the backlash issue we first have to address the mentioned problem. We working on it.
Re: Backlash issues
Postby rodrigjup@gmail.com » Sun Apr 17, 2022 9:57 am
Story so far, bought uc300eth and uccnc software package for my lathe/mill conversion. Almost finished converting, find out uccnc doesnt have a lathe profile yet (odd), switch to mach3, experience reminded me of a program i wrote in the 1980's....in turtle code. Switched to Mach4 , looks promising. Find this forum, Mach4 list of plugins for version 2 don't mention uccnc. In summary, uccnc still busy with lathe profile and mach4 ver2 plug in........ $10k plus spent and game over. My experience from the CAD , CAM software suites are world class commercial packages worth every cent, then into the CNC machine controller/ software and its more like an interest group mucking about when they have the time.
rodrigjup@gmail.com
Re: Backlash issues
Postby BattleFluffy » Thu Jul 18, 2024 11:25 pm
Hello, signed up to say that we have the same issue.
We use UC100 with Mach4, and backlash compensation does not work on the X-axis.
It works fine on the Y-axis.
Backlash compensation was working okay in Mach3 demo. We paid for Mach4 hobby and upgraded the firmware on the UC100 for Mach4, and everything works great except no backlash compensation on X.
It's a big problem for us because we want to machine small gear teeth and even a small backlash can lead to meshing problems.
I can see it's been a while since anyone posted in this thread, was the driver problem ever resolved? What exactly was changed in Mach4 that made this no longer work, and why only in one axis? Maybe if you could share what exactly what was changed in Mach4 that made BC in X axis stop working, then we could figure out a way to work around it.
BattleFluffy
Return to Mach3/4 Discussions
Users browsing this forum: Google [Bot] and 2 guests
