Mach3 PlugIn Clarification with UC300ETH
Posted: Sun Aug 08, 2021 6:46 pm
Hello!
I have recently got a UC300ETH to replace the current USB Smooth Stepper (USS) on my 4 axis CNC. Unfortunately there is no information online (at least I can not find it) regarding the Mach3 plugin setting and functions. Installation is pretty straightforward, but I am now left with few questions regarding how the UC300ETH/Mach3 plugin handle Mach3 settings. I see that there is a plugin diagnostic and setting pages (pictures attached) where you can define "Input functions", "Setup" (for encoder and system frequency), "Analog IO" (with some setting for SRO and FRO?).
My main questions for now would be:
1_What is the difference between setting the Input functions in the plugin or in the classical "port and pins" page of Mach3? Do we first need to define the inputs pins and ports in the Mach3 "port and pins" page and then only assign a function in the plugin page?
3_In the Setup page. Does Max step rate have to reflect the higher Step signal in the system? Does it override the computer system frequency setting that you assign in the first tab of "port and pins" (25KHz, 45KHz ecc...)
4_Analog IO page. What do FRO, SRO, SR PWM and the adjacent numbers mean?
I think the best would be to make a short Mach3 plugin manual where you cover how the plugin and UC300ETH is handling all the tasks...such as backlash, inputs, probing ecc.. and what has to be done to set it up correctly. I am sure other will be interested in knowing more about it.
Thank you!
Best,
Alessio
Thank you!
Best,
Alessio
