Ive been trying to get my PNP NO proximity sensors working on a chinese mach3 bob but I cant get them to register in mach3. The estop is also wired to an input and does work as it should. I also assigned the correct port and pins. Ive been doing some experimenting with @rey8801 but we haven't found a solution yet.
My current wiring schematic is attached below. Just a note, the sensor ground is connected with the input ground via a connection between the negatives of the 5v and 24v powersupply. this would make the sensor circuit work I believe.
I am using this BOB:
which I believe is the same as in this image with some schematics:
Help would be appreciated, thanks!
