MACH3 Import Homing Problems
PostPosted: Tue Mar 03, 2020 4:17 am
by daydreamn1134
I have imported my Mach3 Profile. I have compared axis setup to the working profile in Mach3 and I have got my spindle control working.
Problem:
When I home all Z homes correctly, Y homes, then X exceeds soft limits or hits the limit switch and errors (exceeds limit)
Can you please help?
Thank you!
Re: MACH3 Import Homing Problems
PostPosted: Tue Mar 03, 2020 5:01 am
by daydreamn1134
Just to clarify, I am importing my Mach3 Profile to UCCNC and would like to switch to UCCNC.
Thank you!
PostPosted: Tue Mar 03, 2020 12:24 pm
by ger21
UCCNC is not Mach3, and has different settings, so when you import a Mach3 .xml, you likely still need to go through your settings to make sure everything is correct.
Sounds like your X axis softlimits and/or homing settings need some changes.
PostPosted: Wed Mar 04, 2020 8:28 am
by daydreamn1134
I do realize this, How do I get help on making these changes?
Is there a doc on how to set this up?
PostPosted: Wed Mar 04, 2020 4:34 pm
by ger21
Start by turning off Softlimits, and seeing if it homes correctly. When it does, set up the softlimits so that they are inside the limit switches.
PostPosted: Fri Mar 06, 2020 7:18 am
by daydreamn1134
yes i did this. my best guess is that the steps/units are not correct in the imported profile. even though they match what is in mach3.
PostPosted: Fri Mar 06, 2020 11:51 am
by ger21
Then set them correctly, either by doing the math, or using the calibrate function.
But if they are the same as in Mach3, they should be correct, unless you are possibly mixing units?
If you turn off softlimits, what problem are you having?
You need to provide a much better description of the issues for anyone to be able to help.
