Installing M4 plugin for UC100
Re: Installing M4 plugin for UC100
Postby cncdrive » Fri Jan 22, 2021 3:44 am
Gerry, there are many other users using the plugin without problems. This is why I'm idealess about why it is not working for him, if he did everything as I wrote then it should work.
And Artsoft has one of our UC100 and also a UC400ETH to test with.
Postby ger21 » Fri Jan 22, 2021 12:45 pm
I have licenses for both Mach4 Hobby and Industrial, and if I put the plugin in the plugins folder, it's available in Mach4, even without a controller connected. So it should be working, which is why he should contact Artsoft, as there seems to be something wrong with his Mach4 installation.
Postby cncdrive » Fri Jan 22, 2021 2:07 pm
Hi Gerry, Yes, I agree with you. They could help hopefully, because they even have a UC100 with them, so they can even test it out.
Postby deckel11668 » Fri Jan 22, 2021 5:29 pm
ger21 wrote:I have licenses for both Mach4 Hobby and Industrial, and if I put the plugin in the plugins folder, it's available in Mach4, even without a controller connected. So it should be working, which is why he should contact Artsoft, as there seems to be something wrong with his Mach4 installation.
HE has uninstalled Mach 4, deleted plugins , redownloaded and reinstalled two or 3 times , followed by re installing of the plugins using both manual and automatic installation. You have seen my plugin files so do not know what more I can do in that respect .
I have sent an enquiry to Artsoft so now await their response.
deckel11668
Postby deckel11668 » Fri Jan 22, 2021 10:43 pm
Mach support supplied a remote connection link and while I was having my dinner the problem was resolved in my absence . Came back after dinner and a notepad message told me UC100 was now connecting.
I will ask tomorrow if they can tell me what was wrong for the sake of others who may have similar probs .
I will now embark on the configuration process, but already I have the tool post whizzing about at silly speeds . Probably need a bit of motor tuning but that will be tomorrow.
Thanks to all that have tried to help . Will come back if I can get more info on what I might have done wrong
John
deckel11668
Postby cncdrive » Sat Jan 23, 2021 10:50 am
OK, please let us know what was wrong if you will get the information from Artsoft.
Postby deckel11668 » Sat Jan 23, 2021 11:11 am
cncdrive wrote:OK, please let us know what was wrong if you will get the information from Artsoft.
Will do
deckel11668
Postby frapo » Mon Jul 11, 2022 5:23 pm
hi
I downloaded and installed Mach 4 hobby and installed the plugin for UC100 so far so good.
the green en the blue light from the UC100 USB motion controller is on so it is communicating with my mini lathe.
But when i try to move the axes i have no movement what so ever,the numbers in the mach 4 screen do change how ever.
any help?
thanks frank.
frapo
Return to Mach3/4 Discussions
