AXBB-E Mach3 Homing Problem
Postby MDT » Wed Apr 07, 2021 11:30 am
Good morning everyone, I'm Matteo and I'm new to this forum since I bought myself an AXBB-E that replaces my old controller port. I have 2 issues that I can't solve with this tab and I wanted to know if anyone can give me any suggestions.
- First problem: I use Mach3 and when I go to do the Homing of the axes, start the master engine and not the slave of the Y-axis.
- Second problem: the Probe works perfectly until I connect it to the spindle bit. when I connect it it doesn't work anymore.
Thanks to who can help me.
MDT
Re: AXBB-E Mach3 Homing Problem
Postby cncdrive » Thu Apr 08, 2021 5:11 pm
I beleive there is a setting in Mach3 to be selected to make the master to home together with the slave.
I don't understand your second problem.
Postby MDT » Sat Apr 10, 2021 7:27 am
I have already checked "Home Slave with Master Axis" in "General Config." but it continues to give the problem.
I attach the Mach3Mill.xml file to show you how Mach3 is configured.
As for the Probe, I solved it by reversing the polarity of the plate and the crocodile attached to the cutter.
TKS.
Mach3Mill.zip
(24.9 KiB) Downloaded 625 times
MDT
Postby ger21 » Sat Apr 10, 2021 11:31 am
Home slave with master should NOT be checked if you have two home switches.
Postby MDT » Sat Apr 10, 2021 2:16 pm
I only have 1 home switch for the two axes.
Is the xml file I sent the right configuration file?
MDT
Postby ger21 » Sat Apr 10, 2021 11:52 pm
I didn't look at your .xml
In that case, then you do want to check Home Slave with Master.
Postby MDT » Mon Apr 12, 2021 9:03 am
I attach the Mach3 xml connected to the AXBB-E. Today I removed the check from "A is angular" in the General Config, but the A axis, slave of the Y axis does not move in homing
Mach3Mill.zip
(31.11 KiB) Downloaded 594 times
MDT
Return to Mach3/4 Discussions
