Homing problem ucr201
Postby jedy » Fri Jan 29, 2021 11:06 am
Hello to all the Uccnc forum, I wanted to report a problem that I encounter with mach3 and the ucr201 flyer. When I press homing from ucr201 only the y axis moves. I have this problem only if I use the ucr201.
I wanted to know if this is a problem that others have already encountered and if it will be fixed
My setup is win7 with mach3 and uc100
thanks
jedy
Re: Homing problem ucr201
Postby Soler » Fri Jan 29, 2021 5:34 pm
What do you have set in your home sequence
Soler
Postby jedy » Fri Jan 29, 2021 5:58 pm
I use mach3 and the problem occurs when I use the ucr201 flyer
jedy
Postby jedy » Mon Feb 01, 2021 11:50 am
Anyone using ucr201 with mach3 ?. One of the things for here I bought it is because it is specified that it is compatible with mach3 so I wanted to know if others have had a similar problem and if so how they solved it. Thank you
jedy
Postby cncdrive » Tue Feb 02, 2021 2:45 am
The UCR201 calls the "Ref all home" function of Mach3 when homing, so I don't know why only the Y axis moves at you when homing. :(
Postby jedy » Tue Feb 02, 2021 10:41 am
Thanks for your interest. If I do homing from the mach3 screen the operation is correct so raise the z then the x and finally the y. If I run it with ucr201 this does not happen, I am using an original uc100 could this be the problem ?. I noticed that if I disable the limit switch Pins and I homing with ucr201 x y z they go into homing all together and this in my opinion is not correct
jedy
Return to Mach3/4 Discussions
