I have my UC400 working fine on my win 10 laptop. But i want to use it on one of my XP pc's. I have followed the instruction manual and while the IP4 properties are set up as 10.10.10.11 and the gateway is 255.255.255.0 and I have the plugin installed in the plugin directory of mach3 when I start mach 3 I get an error that the UC400 is not found. When I click on config plugins it says my firmware is up to date. I have tried using the patch cable and a straight thru ethernet cable. In network and sharing when I unplug the cable the connection goes away. When I re-plug it in the connection is restored. I have run the uc utility. It recognized the uc400 and has the serial number. When I click on save the settings it saves. When I go back and run the utility again and click on test the connection I get the error IP and network settings OK. Connection Error! I also used the ucxxsetup,exe file and deselected everything except for the UC400 and it shows that the setup worked with no problem. Any help would be appreciated.
Dan Mauch
