Fusion 360 PP
Posted:
Tue Jan 09, 2024 8:55 am
by andrej
What is the recommended postprocessor for Fusion 360 and UCCNC Turn?
Re: Fusion 360 PP
Posted:
Mon Sep 09, 2024 9:09 pm
by fred47
Hi
I have a same question ....
I use UCCNC software 1.2116 turn version and Fusion 360.there are a postprocessor UCCNC on Fusion galerie but for 3 axis , not for lathe........
what post processor to use?
Is an update coming soon?
Fred
Re: Fusion 360 PP
Posted:
Tue Sep 24, 2024 6:14 am
by Arne9999
I'm using Fanuc in Fusion 360. I've just started, but so far so good (after changing the code to diameter instead of radius...). However, as I mentioned in another post, it moves at the same speed regardless of the operation. So if I set a feed rate of 150mm/min during a cut, it will travel at this speed throughout the entire process... very annoying.
