Edit your Constructor Macro (M99998.txt) and add in the following code {change your spindle speed + feedrate + default jog setting to your preferred number}
- Code: Select all
//This is the Constructor macro which executes once when the application gets loaded
exec.Callbutton(141); // set tool path veiw LEFT (i.e. XZ)
new Thread(delegate () {
SetGcode ();
}).Start();
#Events
private void SetGcode ()
while (AS3.GetLED (25));
Thread.Sleep (50);
exec.Code ("G18"); // set XZ plane
exec.Code ("F1200"); // set Feedrate
exec.Code ("S500"); // Set SpindleSpeed
AS3jog.Setfield(50, 913); //Set 50% jog feedrate
AS3jog.Validatefield(913);
it is also possible to save the feedrate and spindle speed at shudown by editing the desrtuctor macro to save the settings to the profile, and change the constructor macro so that it reloads it from the profile and the settings would therefore be persistent from shutdown to restart.
