Turn software update?
Re: Turn software update?
Postby pinkpanda3310 » Wed Dec 01, 2021 3:05 am
Will this turn software incorporate spindle indexing and live tooling?
pinkpanda3310
Postby cncdrive » Sat Dec 04, 2021 1:16 am
Spindle control with encoder feedback for thread cutting is already working in the UCCNC.
I don't know what live tooling means? Could you please explain?
Postby pinkpanda3310 » Sat Dec 04, 2021 9:17 am
Sorry i must be using the terminology wrong. By live tooling i mean toolpost spindle/ toolpost drill. So if the lathe motor (an a/c servo) has a brake feature one could drill a circumference of holes in the work piece. Rough examples below are pics from the net...
pinkpanda3310
Postby Robertspark » Sat Dec 04, 2021 10:29 am
if you use a servo motor for your spindle motor then this is easy to do setting it up as a C axis, and either have a milling attachment or a drill on your toolpost.
a lot of posts on making a toolpost drill attachment.
Postby pinkpanda3310 » Sun Dec 05, 2021 1:57 am
Aah yes, C axis is what I wanted to say. I'm not particularly concerned with the toolpost spindle itself rather the software for it
pinkpanda3310
Postby betelgueze » Wed Feb 02, 2022 10:47 pm
Hi! In the lathe version. Will there be wizards, like them in Mach3?
Like the Facing wizard or Turn wizzard?
Anyway, I´m looking forward to have a screenset that is made for lathes.
And it would be great to see some of those pictures of your friends lathe. :)
Thanks for a good program !
betelgueze
Postby cpu224 » Fri Feb 18, 2022 5:21 pm
Hello
I have a small lathe that I use as a hobby. Hardware is UC400eth and triplebeast. I'm annoyed with Mach3+4 right now and can't wait for UCCNC to come up with a turning option.
When can you expect that?
Many greetings
Torsten
cpu224
Postby cncdrive » Thu Feb 24, 2022 11:07 pm
Hi, I'm not sure when will we finish the required functions for lathe, but we just finished making our CNC lathe conversation which we use to develop and test these functionalities.
I'm attaching a small video and 2 pictures.
Postby CL_MotoTech » Fri Feb 25, 2022 7:32 pm
Finish it! Finish it!
Or release a beta setup for a test. My lathe conversion is getting close to needing a control. I don't want to have to use Mach 3. I'd gladly test a UCCNC beta if it meant I didn't have to mess with Mach 3 again.
CL_MotoTech
Postby cncdrive » Sat Feb 26, 2022 2:55 am
No, sorry, we are still far from completing the lathe version.
We just finished our lathe conversation, so we using this lathe for the development and testing.
So, it will still take time to make this even beta release.
