Slow feed from Fanuc Post processor
Postby Arne9999 » Mon Sep 23, 2024 12:44 pm
I ihave just got my cnc lathe to work! Im using Fanuc post processor in fusion 360 and it seams to work ok but it feeds with the same feedrate in between cuts which makes it really slow.
I have investigated how to mod the code but it feels a bit tricky. Isnt there any way to change transport speed ?
for examle I faced a big surface yesterday with a feed of 150mm/min. after the cut it traveled back to the start for the next cut at 150mm/min. It would be really nice if this transport was at like 1000 istead before the lead in
Arne9999
Re: Slow feed from Fanuc Post processor
Postby Delco » Fri Sep 27, 2024 12:52 am
Sounds like you are using the free version of fusion without rapids.
Delco
Postby CL_MotoTech » Fri Sep 27, 2024 2:10 pm
Yeah, that's my guess too. I saw somebody complaining about that while also complaining that the free Mach version could only do so many lines of code.
Yikes.
CL_MotoTech
Postby Arne9999 » Mon Sep 30, 2024 7:03 am
Yes that was the case... cant really motivate a payed version of Fusion. But since it is possible to modify the postprocessor I guess there is alternative postprocessors "out there"??
Arne9999
Postby Arne9999 » Mon Oct 28, 2024 8:40 am
But is there any other way to fix this?
I really like Fusion and Im thinking of doing a script that changes the Gcode to rapid moves but to do this in a solid 100% secure way is a bit tricky
Arne9999
