Hybrid stepper or servo system for uc300
Posted: Sun Nov 12, 2017 9:39 am
Hi all,
I currently am running a uc300 usb with mach3 and I have open loop steppers. This was fine for a homemade small router I had built as a prototype but I am now building a new heavy duty frame to migrate all my hardware onto. As I'm upgrading the lightweight frame I am also going to upgrade the positional motors as the weight of the table being moved is now steel and considerably heavier. Prob around 120kg so it is going to be pretty rigid
What my choices are is a closed loop stepper system or a servo system. But I am thinking of using UCCNC instead of mach3 as I've seen it gives better results. I've been looking at these drives and motors;
3HSS2208h-100 with 20Nm nema 42 motor
https://rover.ebay.com/rover/0/0/0?mpre ... 2187432593
Also this servo configuration
https://rover.ebay.com/rover/0/0/0?mpre ... 2411229621
My question is basically this, has anyone got any experience with these options and how do they perform. Also how would I go about if it's possible to have a fully closed loop system to uccnc. Is it possible with the uc300 usb?
Or if anyone else has any options of better motors and drives to get? My budget is max around £1000.
Dave.
Dave.
