In 1.2116 or later you can use G7 for diameter and G8 for radius mode.
Sorry, now I see your problem: the user manual for 1.2116 does not mention G7 and G8. Please, download 1.2117, the manual in it contains the descriptions:
Lathe Diameter Mode: G7
Program G7 to enter the diameter mode for axis X on a lathe. In lathe diameter mode the X axis
moves will be 1/2 the distance to the center of the lathe. For example X1 would move the cutter to
0.500 Units from the center of the lathe thus giving a 1 Unit diameter part.
Lathe Radius Mode: G8
Program G8 to enter the radius mode for axis X on a lathe. When in lathe radius mode the X axis
moves on a lathe will be the distance from the center. For example X1 would result in a part that is
2 Units in diameter. G8 is default on the software startup.
As far as I know none of us uses Fusion, so I can't tell you anything about its postprocessors.
