M61 T# macro fquestion
Postby bhdavis » Wed Jul 24, 2024 11:15 pm
On my new Rapidchange ATC tool changer I type M61 T# to change the number of a tool in the spindle if needed. It's not needed often but does come in handy occasionally.
I'd like to create a screen button for the command. However I'm not sure how to code the macro so it asks me for the tool number to use. I think I can create a pop-up box but it's been a while since I did that. Then further though I don't have a clue on how to make a tool number I insert in the pop-up box get assigned to the tool in the spindle.
Could someone point me in the right direction?
BH
bhdavis
Re: M61 T# macro fquestion
Postby bhdavis » Fri Jul 26, 2024 11:11 am
I created a test macro M20099 with the following:
// test input box
string val = exec.TextQuestion("Enter loaded tool number.");
exec.Code("M61 T()");
I get the popup box and can enter a tool number but it does not record it on the T# data cell on screen. If I replace the () with a tool number, i.e. M61 T5, that works.
So the macro concept works but not the part where what I enter for a tool number in () gets recorded on screen.
I imagine I'm way off here on the concept of how to do this but thought I'd try a few things.
BH
bhdavis
Postby ger21 » Fri Jul 26, 2024 11:40 am
Try this:
string toolch = "M6 T" + val;
exec.Code(toolch);
Postby bhdavis » Fri Jul 26, 2024 12:25 pm
Thank you Gerry. Worked perfectly.
BH
bhdavis
Postby bhdavis » Fri Jul 26, 2024 6:36 pm
Drats.....forget that "works perfect" comment above. I posted that after trying it in Demo mode and before putting it on the CNC.
What you gave me was basically calling for a tool change from one bit to another. I already have that covered with my individual buttons as you'll see in the attached screen shot.
What I need is to rename a tool that is already in the spindle.
Say for example I'm doing some alignment testing on the tool rack. I might have T3 in the spindle but my open holder is T1 and I want the tool in the spindle to be renamed T1.
What I would type in the MDI is: M61 T1
That would change the tool recorded in UCCNC from T3 to T1.
Or if I had no tool in the spindle but T1 etc was recorded in UCCNC, then typing: M61 T0 would change the recorded tool to T0.
So instead of having to type M61 T# I could just push the screen button and it would ask me for the number.
Thanks Gerry,
BH
bhdavis
Postby bhdavis » Fri Jul 26, 2024 8:48 pm
Okay. Here is your suggested code:
exec.Code(toolch);
which executes a tool change.
Here is my working M61 T# code that changes the existing recorded tool to a new T# when I type M61 T# in the MDI box:
int newTool = exec.Getnewtool();
if (newTool < 0)
return;
else
exec.Setcurrenttool(newTool);
I've combined the two as follows (plus numerous other ways):
string Setcurrenttool(newTool); = "M61 T" + val;
but am getting a code error message when entering this macro into the MDI. Obviously I'm only guessing as I don't have much background in doing this.
Thoughts?
Thanks for you time,
BH
bhdavis
Postby ger21 » Sat Jul 27, 2024 7:19 pm
If I understand correctly, you just need this:
exec.Setcurrenttool(val);
Postby bhdavis » Sat Jul 27, 2024 8:27 pm
Thanks Gerry. I'll give it a try shortly. I just hauled home a used Minimax S45 18" bandsaw and need to unload it before playing with the CNC.
BH
bhdavis
Postby bhdavis » Sat Jul 27, 2024 10:31 pm
Gerry,
I get "script errors" when I run that last suggestion. But, yes, I think you understand what I'm trying to do.
BH
bhdavis
Postby dezsoe » Sun Jul 28, 2024 5:24 am
Here it is fixed:
double val = exec.Question("Enter loaded tool number.");
exec.Setcurrenttool(Convert.ToInt32(val));
Users browsing this forum: Bing [Bot] and 3 guests
