Event handler - documentation
Postby Oursamiel » Thu Jul 18, 2024 8:49 pm
I’m looking for available documentation about « event handler ». Perhaps I’m not using the right words.
What I have in mind is to be able to register an external event that generates a « tailored soft stop » rather than a *E-stop ».
If an E-stop event is triggered UCCNC stops all movements, following an emergency. Depending on how the spindle is interfaced, it stops the spindle as well - or not.
What I have in mind is to be able to handle an event triggered by an external condition - for example an excess temperature in the spindle. Following the registered event, I’d like to run a set of command to place the machine in a safe state.
I thus need some sort of « event handler ».
Any reading to suggest ?
if you think education is expensive, try ignorance
Oursamiel
Re: Event handler - documentation
Postby cncdrive » Thu Jul 18, 2024 10:39 pm
There is a Fault signals plugin which doing this.
You can attach conditions and signals to commands.
A command could a stop command, it is a soft stop with the axes stopping with decceleration and the Reset button does not activate.
Postby Oursamiel » Fri Jul 19, 2024 3:54 am
thank you, I will have look at this topic.
Oursamiel
