Can UCCNC ignore G20/21 but still warn about other codes?
Postby SteveM » Wed Mar 20, 2024 3:11 pm
Most of my post processors add in the units code G20/21, I only use metric and I understand that UCCNC doesn't care about metric/imperial as you use a metric or imperial profile.
I have UCCNC set to warn about Gcodes it doesn't support, but since there is usually a G21 in there it keeps warning me about it, I'd like UCCNC to ignore the units Gcode but warn for other Gcodes, is this possible? Or even just give a list of the Gcodes it's warning about.
It may actually be handy if UCCNC read the G20/21 and opened a window asking if you are in the right profile, something like "This is a metric Gcode program, are you using a metric profile?" While not relevant to me as I only use metric, it may be handy for others.
SteveM
Re: Can UCCNC ignore G20/21 but still warn about other codes
Postby SteveM » Fri Mar 22, 2024 11:35 am
Was this a stupid question with an obvious answer?
SteveM
Postby ger21 » Fri Mar 22, 2024 12:40 pm
Edit the post, or turn off the warnings.
Postby SteveM » Fri Mar 22, 2024 7:04 pm
Ok, I'll probably turn off the warnings as the post on my CAM is a pain to understand.
Steve
SteveM
