AXBB-E connection wuth UCCNC
Postby Arne9999 » Mon Jan 29, 2024 1:00 pm
I have succsessully installed a AXBB-E to UCCNC on my laptop. However i have one issue.
When connecting the 5V input to the computer USB (and the ethernet calble) it works fine.
If I supply the 5V from another source the connection is lost after a short while...So the question is if it is possible to feed the 5V form something other than the USB port on the computer?
Arne9999
Re: AXBB-E connection wuth UCCNC
Postby formantjim » Mon Jan 29, 2024 3:31 pm
Yes feed a 5 volt from a good stable source with the specified current to supply the AXBB-E. Your laptop will be limited on the current output it can supply via USB.
formantjim
Postby cncdrive » Mon Jan 29, 2024 3:35 pm
If the connection is lost it is because the 5Volts power source you using is not stable.
Make sure to use a good stabilized powersupply with constant 5Volts voltage with good noise filtering on the mains lines.
