Can you write all status message to file?
Postby Mudden » Wed Jan 10, 2024 9:43 am
Hi!
We write a lot of information in the UCCNC status message window.
Is it possible to dump the information in the status message window to a file on disk, to open in Notepad?
I know I can write messages to file from macro, but is there already a built in functionallity to somehow get the messages in the status window over to an editor? I want to be able to perform a search-operation in the output messages.
Mudden
Re: Can you write all status message to file?
Postby ger21 » Wed Jan 10, 2024 11:54 am
You could open a file and write each message to the file when you write it to the status window. I've never done it, so I can't tell you how, but it should be possible.
Postby dezsoe » Wed Jan 10, 2024 2:08 pm
Normally when I write to the status box I also write to the console. (Console.WriteLn) In 1.2114 the Console plugin was rewritten and in the plugin window you can right click to get a local menu where you can copy all the contents of the console.
Postby dezsoe » Thu Jan 11, 2024 6:10 pm
To read the status box use AS3.Getlist() then use a StreamWriter to write the lines in reverse order:
// List status box messages to file
List<string> lst = AS3.Getlist(2);
using (System.IO.StreamWriter sw = System.IO.File.CreateText(@"E:\status.txt"))
  for (int i = lst.Count - 1; i >= 0; --i)
    sw.WriteLine(lst[i]);
  sw.Close();
Result:
