Modbus Master and Haunyang GT series Inverter
Postby davidrid » Mon Jan 01, 2024 7:22 pm
Can somone please, tell me where i can find information on how to setup uccnc using modbus to turn spindle on and off and controll speed using haunyang gt vfd.
i've been able to get modbusEZ 16 to turn spindle on and off but it turn it on and runs at 24000 rpm and not its able to controll speed. Sact show blank while Sset shows 6000
Also tried hyplugin14 but was not able to get modbus data back
Tried modbus master and was able to start loop and get spindle to run and then change 1 to 5 in varable table and start loop to shut down but, im lost after that.
Any help would be greatly appricated.
davidrid
Re: Modbus Master and Haunyang GT series Inverter
Postby Battwell » Tue Jan 02, 2024 9:26 pm
search in the plugins thread. i tested the hy gt series when they first came out.
dan modified the plugin as i wanted then.
Postby Battwell » Tue Jan 02, 2024 9:34 pm
viewtopic.php?f=14&t=481&hilit=gt+series+plugin&start=20
pages before and after this one. for how we found it
Postby valhallaCNC » Tue Jan 02, 2024 10:44 pm
viewtopic.php?f=2&t=3366
Check here also a lot of info...
valhallaCNC
Postby davidrid » Wed Jan 03, 2024 1:11 am
Well had it runing on uccnc version 1.211
Than decided to upgrade to 1.213 and now i can get spindle to turn on and off but cannot control the speed.
M@ says something this in the m20002 macro about
// UCCNC screen fields existing
ushort MaxSpindleSpeedDRO = 178;
ushort UptospeedLED = 800;
ushort VFDcommfaultLED = 801;
ushort SactDRO = 870;
ushort SoverrideDRO = 2451;
// UCCNC screen additions you must add these for the macro to work properly
// NEW UCCNC screen fields these are showfieldnb type objects and must be added
int VoltageDRO = 20010;
int CurrentDRO = 20011;
int SpeedDRO = 20012;
int PowerDRO = 20013;
int TorqueDRO = 20014;
not sure if i need to change anything or not to control speed
davidrid
Postby Battwell » Thu Jan 04, 2024 12:51 pm
are you using the same screen as previously?
Postby davidrid » Thu Jan 04, 2024 1:25 pm
went from 2.111 to 2.113
davidrid
Users browsing this forum: Bing [Bot] and 26 guests
