connect leadshine / carte UCCBB1 / UCCNC
Postby fred47 » Sun Dec 24, 2023 7:53 am
Hello everyone,
Being a novice in CNC; I need to help for connect my leadshine CSD508 Driver to my UCCBB1 board. I would like to do my first tests and run the motor. I am having trouble configuring the X axis in my UCCNC software.
the power supplies are OK on all sides, the motor also hums........ Is my driver/card wiring correct????? (green and white wire)
My problem is that I enter the DIR PIN (O2) and the PORT (1) in the setup interface, it returns to zero as soon as I validate........ I don't understand why?
Bad settings???? bad wiring ????
Thank you for your help
Fred
fred47
Re: connect leadshine / carte UCCBB1 / UCCNC
Postby CT63 » Sun Dec 24, 2023 12:10 pm
Should be "2" not "O2"... then press enter and save.
CT63
Postby ger21 » Sun Dec 24, 2023 3:10 pm
What motion controller do you have? If you have a UC300, you have to use port 2 or port 3.
Postby fred47 » Sun Dec 24, 2023 5:36 pm
yes
I have the UC 300 ETH and now the recording works in the setup...
how to turn the engine manually now?
fred47
Postby fred47 » Tue Dec 26, 2023 1:34 pm
Hi
I just connected the card with a crossover cable but the computer does not recognize the utc300 eth card
Where does the problem come from ?
Thx
fred47
Postby cncdrive » Tue Dec 26, 2023 4:39 pm
Maybe you forgot to setup the network card IP address.
Follow the motion controller users manual, it describes the step by step process.
Postby fred47 » Tue Dec 26, 2023 5:32 pm
yes I reread the manual from the beginning, changed my crossover cable and now everything works!!!
the first motor turn , it s a good start!!
thank you
fred47
