Connecting Driver to UC300ETH
Postby PowerCube » Wed Oct 11, 2023 12:20 pm
Hello everybody,
I have the following basic (I hope so) problem, which I'm not able to solve.
I have the following setup:
- UC300ETH, connected to my laptop running UCCNC
- HDBB2 breakout board connect to the UC300 Port #2 via a IDC26-IDC26 ribbon cable
- Closed-loop Stepper Drive CL86T by stepperonline connected to the HDBB2 RJ45-A-Axis-connecter via a Patchcable
- NEMA 24 Motor connected to the driver.
Now as I understand I need to setup the A-Axis in UCCNC.
As far I chose the following settings:
- Step pin: 8, port: 2
- Dir pin: 9, port: 2
When I try to move the axis I can hear a little noise inside the motor for a split second and thats it.
What else do I need to setup?
Is there maybe a youtube video for that kind of setup explaining how to get things running?
PowerCube
Re: Connecting Driver to UC300ETH
Postby PowerCube » Wed Oct 11, 2023 4:25 pm
I forgot to post a picture of my setup:
questions that additionally popped up in the mean time:
- is the 12 V supply for the HDBB2 necessary for the motor to run?
- The manual of the driver sais: Please note: For V3.0 version, the default control signal voltage is 5V. If need to connect 24V, a 2KΩ should be added.
-->Should I do that?
PowerCube
Postby PowerCube » Thu Oct 12, 2023 11:34 am
Hey everyone,
Update:
- I connected driver+Stepper to an existing cnc machine from china (JMC) and it works flawlessly.
- I discovered that when I try to move the stepper with the UC300 it loses its torque and i can turn the axis by hand as long as the UC300 sends its signal to the driver.
PowerCube
Postby cncdrive » Thu Oct 12, 2023 1:27 pm
Try to lower the acceleration and velocity of the axis in the UCCNC software.
Postby PowerCube » Wed Oct 18, 2023 11:05 am
Problem solved,
it was the RJ45 adapter I used. It has the wrong pinout for this task, my bad.
PowerCube
Users browsing this forum: Dawid92 and 39 guests
