start/stop motion when cutting curves
Postby jonathanmahnken » Fri Sep 22, 2023 9:32 pm
when cutting circles and arcs im getting a start stop motion, how can I fix this
jonathanmahnken
Re: start/stop motion when cutting curves
Postby charliem » Sat Sep 23, 2023 10:53 am
Open UCCNC and got to configuration/General settings and make sure Constant velocity mode is checked and also make sure the "Stop at Angles > " is set to 89.
Regards
Charlie M
charliem
Postby jonathanmahnken » Sat Sep 23, 2023 7:59 pm
will the accuracy of my parts suffer by switching to constant velocity?
jonathanmahnken
Postby charliem » Sat Sep 23, 2023 8:43 pm
No. Not at all. This is how I have my software set and I don't have any issues.
Regards
Charlie M
charliem
Postby ger21 » Mon Sep 25, 2023 10:38 am
Depending on how your circles are programmed, you may need to increase the error tolerance settings.
Increasing acceleration can also help.
Postby jonathanmahnken » Mon Sep 25, 2023 9:40 pm
Thanks. In your opinion what are some safe starting points for acceleration considering that I'm using an older machine with stepper motors and ball screw drives
jonathanmahnken
Also my circles are programmed by vectric vcarve pro
jonathanmahnken
Postby jonathanmahnken » Wed Oct 11, 2023 7:25 pm
Ok so I switched to CV mode, and everything seems to be working fine, but my arcs look like a series of straight lines. How do I increase the resolution of my arcs. I am perfectly fine with it moving slower through the arc.
jonathanmahnken
Postby ger21 » Thu Oct 12, 2023 10:43 am
What are your CV settings set to?
Postby Battwell » Mon Oct 16, 2023 10:11 am
in vectric. select the vector curve and use convert to curves function.
set a tolerance of eg 0.2mm and preview it.
if happy save it.
recalculate the toolpath and save code.
this will make your code output much smoother!
