by Delco » Thu Mar 09, 2023 2:05 am
You need to set the right ports and pins for homing that its connected to for each axis , then you need to home the machine , then set your soft limits values - they dont work as hard limit switches unless you configure the ports/pins for limits which you dont need to do if soft limits set properly.
