UC_400ETH connection issue
Postby Schaaper » Sat Dec 31, 2022 10:36 pm
I had my older labtop stolen in a resent break in; Controller worked fine on that computer. Bought a new computer that runs Windows ll, having the issue of it not finding the controller after following all the instructions in the manual I took it to best buy to see if their technician can help. They could not get it to connect also. All connections, IP's so forth have been verified.
Only question that has raised is; is the comptroller compatible with windows 11. If some one can comment to this that would be great.
Schaaper
Re: UC_400ETH connection issue
Postby ger21 » Sun Jan 01, 2023 3:59 am
Yes, it should work with Windows 11.
Post all of your network settings.
Postby cncdrive » Sun Jan 01, 2023 1:29 pm
Networking works the same on all operating systems, because it is based on standards, so the UC400ETH networking works on all Windows OSes including Windows 11.
Does the UCx00 utility tool sees your UC400ETH? Does the controller answers to ping?
Maybe you could post your IP settings of your network card and IP settings of your UC400ETH with the UCx00 utility tool. (printscreens)
Postby Schaaper » Sun Jan 01, 2023 11:49 pm
These are my network settings
I can ping the comptroller, I have ruled out cable
The UC400ETH -comptroller is not listed anywhere and says it can not be found
I am Running UCCNC from Stepcraft software.
I installed Mach3 to see if it would work however same issue says comptroller cannot be found
Network settings
Schaaper
Postby cncdrive » Mon Jan 02, 2023 2:58 am
Do you ping 10.10.10.11 ip address?
Postby Schaaper » Mon Jan 02, 2023 7:17 pm
This is what I get back when I ping 10 and 11
Nothing back from 11
Schaaper
Postby Schaaper » Mon Jan 02, 2023 9:22 pm
Got a call from Hugo at Stepcraft, he logged on remotely and was able to get it going using 10.10.10.11, 255.255.255.0 he added a gateway ip address of 10.10.10.10 at it seam to be working.
Bigg shout out to Hugo, thanks for the support
This was a unique issue as my ethernet port was using my wifi IP for some reason.
I thank you for your efforts and hope if someone else has this issue it will help them get going also.
If i have another issues i will post
Schaaper
