UCCNC and Arduino
UCCNC and Arduino
Postby camivic » Sat Dec 31, 2022 5:27 pm
Hi everyone.
I would like to start studying the possibility of communicating from UCCNC to an ARDUINO.
Could you point me to a simple guide to get started?
Maybe even a simple Arduino sketch that I can use as a base.
Thanks to all and happy new year.
Vincenzo
camivic
Re: UCCNC and Arduino
Postby camivic » Mon Jan 02, 2023 9:57 pm
For the moment I have solved: I found an excellent sketch for arduino, configuring some "READ INPUT" and some "READ INPUT REGISTER".
With the "READ INPUT" everything works, while with the "READ INPUT REGISTER" connected to the Arduino A0 output, I don't understand what code to insert in the UCCNC macro in order to vary the SRO (or FRO).
Can anyone suggest me a solution?
Thank you.
camivic
Postby dezsoe » Tue Jan 03, 2023 10:10 am
Here is a sample macroloop from my archive which handles analog and digital inputs/outputs:
// Arduino Modbus I/O sample
ushort Inputs = 0;
ushort Pot1 = 0;
ushort Pot2 = 0;
exec.GetModbusregister(0, out Inputs);
exec.GetModbusregister(4, out Pot1);
exec.GetModbusregister(5, out Pot2);
int FRO = Convert.ToInt32(AS3.Getfield(232).Replace("%", ""));
int JRO = Convert.ToInt32(AS3.Getfield(913));
int newFRO = (int)((double)Pot1 / 1023.0 * maxFRO / 5.0) * 5;                   // 5% steps
int newJRO = (int)((double)Pot2 / 1023.0 * 100.0);
if (newFRO != FRO)
  AS3.Setfield(newFRO, 232);
  AS3.Validatefield(232);
if (newJRO != JRO)
  AS3jog.Setfield(newJRO, 913);
  AS3jog.Validatefield(913);
int newInputs = ((int)Inputs & 0x0F) ^ 0x0F;                                    // 4 inputs, change to active high
if (lastInputs == 16) lastInputs = newInputs;
if (newInputs != lastInputs)
  int change = newInputs ^ lastInputs;
  // NC reset switch -> force reset to switch state
  if ((change & 0x01) != 0)
    if ((newInputs & 0x01) != 0)
      exec.Callbutton(513);
    else
      exec.Callbutton(512);
  // Compare SPST switch state to screen button state -> press button if needed
  if ((change & 0x02) != 0)
    if (((newInputs & 0x02) != 0) != AS3.Getbuttonstate(114))
      exec.Callbutton(114);
  // NO pushbutton
  if ((change & 0x04) != 0)
    if ((newInputs & 0x04) != 0)
      exec.Callbutton(130);                                                     // Button pressed
//  else
//    exec.Callbutton(0);                                                       // Button released
  // NO pushbutton
  if ((change & 0x08) != 0)
    if ((newInputs & 0x08) != 0)
      exec.Callbutton(522);
//  else
bool LED1 = exec.GetLED(19);
bool LED2 = exec.GetLED(54);
bool LED3 = false;
bool LED4 = false;
ushort digitalOut = (ushort)((LED1 ? 0x01 : 0) + (LED2 ? 0x02 : 0) + (LED3 ? 0x04 : 0) + (LED4 ? 0x08 : 0));
ushort analogOut1 = (ushort)(AS3.Getfielddouble(2451) / AS3.Getfielddouble(178) * 255); // Overridden RPM / max. RPM
ushort analogOut2 = (ushort)(0);
ushort[] data = new ushort[3];
data[0] = digitalOut;
data[1] = analogOut1;
data[2] = analogOut2;
exec.SetModbusregisters(10, data);
#Events
const double maxFRO = 150.0;
int lastInputs = 16;
Postby camivic » Tue Jan 03, 2023 2:16 pm
Thanks dezsoe, i try it.
camivic
Postby formantjim » Tue Jan 03, 2023 2:42 pm
Hi Camivic I would be interested to see that sketch for the Modbus Arduino if you could share please?
formantjim
Postby Battwell » Wed Jan 04, 2023 1:20 am
I played with a couple of mega a few years ago using modbus
Made a great control panel :-)
Gives lots of extra io and analogs .
https://youtu.be/Mxr_4iRQsdQ
Postby camivic » Wed Jan 04, 2023 9:43 am
formantjim wrote:Hi Camivic I would be interested to see that sketch for the Modbus Arduino if you could share please?
Hi formantjim,
attached you can found the sketch and library used with Arduino in Slave Modbus function.
Ciao.
PLC_Uno.zip
(8.91 KiB) Downloaded 288 times
camivic
Postby formantjim » Thu Jan 05, 2023 1:22 am
Many thanks. Nicely commented out I will give it try at the weekend.
I'm looking to build a quick and simple Modbus tester for the various pieces of software my company use with our vendors instruments. It will be a simple battery powered device using an UNO with Analogue values coming in via 4 to 20mA or a potentiometer and be read by the UNO and displayed in other software.
formantjim
