edit button and limit machine
Posted: Fri Dec 02, 2022 1:50 pm
Hello everyone
I'm finishing setting up my cnc machines and I wanted to make some small changes:
- I would like to set the cycle start button (screen button and real button on the electrical panel) to be operable only if the home LEDs are true!
otherwise I send a message on the screen. The only idea that came to my mind is to create a MXXXXX macro and assign it to the onscreen button, but doing so when I press the
button from the control panel the macro is not taken into consideration as the inputXX button is linked to the CycleStart(128) function.
Does anyone know a better way to do this?
- I have an ATC system with tool magazine in Y1000 X0-X500 across the width
I would like to set the soft limits so as not to include the tool magazine in the work area, but by doing so I cannot access the tool magazine from my M6 macro
is there a way to use that workspace only via script in macros?
do you have any ideas about it?
Thank you all. I look forward to your support
