Version 1.2111 Questions
PostPosted: Tue Sep 20, 2022 8:04 pm
by bhdavis
Running the router today with version 1.2111 it occurred to me to check for updates. I found the current version is 1.2113.
I searched for what was added on the newer version and couldn't find anything.
My questions would be:
1) What is new and or fixed?
2) If I reinstall with the newer versions an I keep my existing screen setup?
BH
Re: Version 1.2111 Questions
PostPosted: Tue Sep 20, 2022 9:06 pm
by dezsoe
1. You can find all the changes in this topic.
2. If you modified one of the built-in screensets then it will be overwritten. You should always make a copy first with another name and modify that instead of the original. Here are some steps to save your work:
In 1.2111 there was only the old screenset which has the pictures in the Flashscreen\BMP\Defaultscreenset directory and the screenset file Screens\Defaultscreenset.ssf. Create a directory, e.g. Flashscreen\BMP\MyScreen and copy all the images from Defaultscreenset. Go to the Screens directory and make a copy of Defaultscreenset.ssf as MyScreen.ssf. Now open your profile with Notepad and change the second line from "mainscreenfilename=Defaultscreenset" to "mainscreenfilename=MyScreen". Now if you start UCCNC you should see the same as before, but now you can update the program. To be safe, make a full copy of the UCCNC directory before updating and you'll have a backup if anything goes wrong.
PostPosted: Fri Sep 23, 2022 11:25 pm
by bhdavis
Thanks. Much appreciated even though it took me a few days to reply.
BH
