Hello,
I'm getting a lot of erratic 'Probe did not touch!' errors while using the probing functions.
Sometimes the probe routine (Circle Inner) starts, but mostly not, and errors out with the 'Probe did not touch!' error.
When it does start, the second or third probing position errors out with the same error.
My setup is as follows:
Probe 1 is a touch plate, active high.
Probe 2 is an 3d touch probe, active low.
Could the active low/active high part of the probes be the cause of the troubles? The diag screen shows the probe as stable off.
Greetings,
Emile
