Axbbe wiring to Folinn HB0101
Postby Gawie » Sat Aug 27, 2022 1:42 pm
Please help! how do I wire my Axbbe to the att drawing of a Folinn Vfd. I would like to contolle the spindle speed from my computer. Have the 10 V wire - AO1, Forward pin2 port 2. Then there is a 5VO and 24VO.
On the Vfd I have 10v ,AI1, comm,S1-S4. Please help,what goes where.
Gawie
Re: Axbbe wiring to Folinn HB0101
Postby MikeM » Sun Aug 28, 2022 1:32 pm
Hi Gawie,
Follow the wiring diagram example in the AXBB-E manual as below:
AXBB_E manual wiring example
That implies the following:
AXBB-E---------------------to---------VFD
O2 (as an example)------to---------S1
24V0------------------------to--------COM (COM of the S inputs on VFD)
AO1-------------------------to--------AI1
5V0--------------------------to-------COM (COM of analogue input on VFD)
You need to set the jumper inside the AXBB-E to output 0-10V
MikeM
Postby Gawie » Wed Aug 31, 2022 7:21 am
Hi Mike. Thank you for the reply. Att is a picture of the vfd terminals. My problem is that I do not know where the 5v0 and 24v0 must go because there is only one com port. I treid to get info from the Chinese manufacturer but there is a translation problem between us. I am so close, only the spindle.
Gawie
Users browsing this forum: Bing [Bot] and 29 guests
