Can UCCNC Talk?
Can UCCNC Talk?
Postby mark68 » Wed Aug 17, 2022 4:27 pm
Is it possible to have speech of a text string or message box, Mach3 has this function with a simple "SPEAK" command?
mark68
Re: Can UCCNC Talk?
Postby ger21 » Wed Aug 17, 2022 4:45 pm
Possibly with a plugin or maybe macroloop using this info?
https://www.c-sharpcorner.com/UploadFil ... n-C-Sharp/
Re: Can UCCNC Talk?
Postby mark68 » Wed Aug 17, 2022 6:58 pm
Excuse me as I'm not a programmer, I'm slowly learning how to edit the Macros more through trial and error.
I have tried to run a new macro with code the same as you linked to and other examples i found but in all cases I cannot get passed the first few lines without UCCNC console throwing up an error. As an exmpale "using system" returns this below. Am I correct in thinking the macro's are already using System?
I have downloaded windows system.speech.dll and copied that into UCCNC folders at top level and pluggins ( I know this isn't making a plugin)..
I have worked out how to run a .wav file from within any of the macro's where i could record predefined sentences but would prefer to have any marco read a text string within it's own code if possible and/or a message box which we know can be created easily.
<!> Last error dated: 8/17/2022 7:48:11 PM
<!> In macro: M2005
<!> CS1003 | in line: 10 | error text: Syntax error, '(' expected
<!> CS1026 | in line: 10 | error text: ) expected
<!> CS1003 | in line: 11 | error text: Syntax error, '(' expected
<!> CS1026 | in line: 11 | error text: ) expected
<!> CS1003 | in line: 12 | error text: Syntax error, '(' expected
<!> CS1026 | in line: 12 | error text: ) expected
<!> CS1003 | in line: 13 | error text: Syntax error, '(' expected
<!> CS1026 | in line: 13 | error text: ) expected
using System;
using System.Windows.Forms;
using System.Speech;
using System.Speech.Synthesis;
namespace TextToSpeechConverter
ger21 wrote:Possibly with a plugin or maybe macroloop using this info?
mark68
Re: Can UCCNC Talk?
Postby ger21 » Wed Aug 17, 2022 7:33 pm
Not a programmer either.
Not sure if you can call those in a macro, and if you can, the syntax will most certainly be different.
Users browsing this forum: No registered users and 34 guests
