I have a newly acquired used Router and have converted it to UCCNC. All is well except for two damaged proximity switches.
I have replaced them with "apparently" the same specification. I actually tried two types. 5/12 volts and 6/12 volts. Both will signal proximity, but the LED is very dim and does not register on the diagnostics page. (the original good one does register) Whereas the originals have a very bright LED`s on both the remaining good one and a broken one which no longer has a switch function. The measured supply voltage is 5.2 and I suspect the new ones either need ~6 volts or I have something missing in my UCCNC settings
All switches are set NC. I have tried them NO and no difference.
If there is anything please in the setup that might ring a bell with you? I would be most grateful for for your help.
Rod
