rotary axis
rotary axis
Postby naijin » Sat Jul 16, 2022 9:18 am
How does one calibrate the rotary axis? any tips, ideas or information would be greatly appreciated.
Regards
Nick :D :?: :D
naijin
Re: rotary axis
Postby Loren » Thu Jul 28, 2022 12:01 pm
If it has a chuck, chuck up a piece of square stock that you can place a digital protractor on. Take the protractor reading. Us the calibrate function, telling the axis to rotate 10 times (3600 degrees.) Take another protractor reading and then input that into the calibration.
Loren
Re: rotary axis
Postby charliem » Mon Aug 08, 2022 9:22 am
So the rotary axis is set up in steps per degrees. depending on if it is belt driven or what ever the gear ratio is.
If your Motor is 200 steps per rotation and you have 10 micro steps thats 2000 steps per rev. Multiplied by lets say 2.3 :1 gear ratio is 4600 / 360 = 12.77 steps per degree.
200 * 10 = 2000
2000 * gear ratio(2.3) = 4600 /360 = 12.77 degrees per step.
Hope this helps.
Regards
Charlie M
charliem
