uc400eth mach3 plugin issue
Postby charliem » Sat Jun 18, 2022 12:26 pm
OK So I started out on a win 10 computer with mach3 and after installing the uc400eth plugin , once in mach3 /configure plugins the plugin is there and I enable it and restart mach3 the plugin is disable and will not stay enabled. So I figure it must be a win 10 thing and down grade to win7 sp1. I still get the same thing.
If I enable the plugin I even selected save settings and restart. Its the same thing the plugin is disabled.
Can someone give me a idea as to why this is happening? UCCNC works as expected.
Thanks.
Regards
Charlie M
charliem
Re: uc400eth mach3 plugin issue
Postby ger21 » Sat Jun 18, 2022 1:36 pm
Do you have a Mach3 license, in your name?
Postby charliem » Sat Jun 18, 2022 1:41 pm
Hi Ger,
Yes I do have a valid license for mach3.
Regards
Charlie M
charliem
Postby ger21 » Sun Jun 19, 2022 12:13 am
If you are sure it is starting and saving with the correct profile, then I would probably create a new profile from scratch and see if that works. Might be a bad .xml file.
Postby charliem » Sun Jun 19, 2022 9:59 am
OK so I now have everything sorted out. I made another profile and it worked as expected. After some messing around just for the heck of it I selected Function CFg and selected reset device sel and restarted Mach3 and it worked as expected. So no now all is good. Thanks.
Regards
Charlie M
charliem
