Z axis runs negative
Postby Rudi Aerts » Mon Jun 13, 2022 2:06 pm
Hi I can't get my cnc to work properly. When I run the G code configured in fusion 360 for UCCNC, the Z axis will run in a negative way. Instead to bore down it will go first down then bore upward. in attachment my setup and the Gcode.
Rudi Aerts
Re: Z axis runs negative
Postby charliem » Mon Jun 13, 2022 10:11 pm
If you jog the z axis does all work as expected?
Regards
Charlie M
charliem
Postby Rudi Aerts » Tue Jun 14, 2022 6:32 pm
charliem wrote:If you jog the z axis does all work as expected?
It is solved, I needed to invert the activ low from the direction signal. But thanks for the resonse. Do you know if I am able to plugin a IMach P4 S pendant.
Rudi Aerts
Postby dezsoe » Tue Jun 14, 2022 6:40 pm
If it is the VistaCNC P4-S then you can download its plugin for UCCNC.
