M31 tool length help...
Postby krsykes23 » Wed May 25, 2022 5:47 pm
I'm asking for help with simple Tool Length probing. I'm using the M31 macro supplied with UCCNC, as I cannot figure out the Probe facility and all I need to do is measure the length of the tool. I did change the supplied M31 macro, from G44 to G43.
I have a fixed tool length probe/sensor positioned at X98.2 and Y1.8. It triggers at exactly 7.0 in Z (LOWER) from the height of the spoilboard. On my previous Mach3 setup, I would run the M31 Tool Length macro if I changed a cutter or skimmed the spoilboard. Obviously, after skimming the spoilboard, I would adjust the difference in Z to the exact trigger point of the sensor.
The macro works as it should, by moving to the X and Y coordinates of the sensor and it probes twice. I have a field (169 Tool Offset Z) on the screenset and after running the M31, this field updates to 8.0. I'm puzzled as to where is this figure 8.0 coming from? I ran three tools with the M31, all of which are different lengths, so I was expecting different values to be updated in the Tool Offset Z field but the field always returns a value of 8.0.
I appreciate that I haven't yet set the spoilboard to sensor trigger point in the macro (as I don't know how or where to add this!) but if could someone can assist me with this, I'd be grateful. Thanks.
M31.txt
(2.14 KiB) Downloaded 263 times
krsykes23
Users browsing this forum: Bing [Bot] and 35 guests
