Page 1 of 2
mm / inch
PostPosted: Wed May 11, 2022 3:07 pm
by CADdy
Hi all,
are G20 /G21 not in UCCNC implemented?
Peter
Re: mm / inch
PostPosted: Wed May 11, 2022 4:37 pm
by ger21
No.
Re: mm / inch
PostPosted: Wed May 11, 2022 7:14 pm
by CADdy
Well, then I could work with the scale factor after all. I have a G-code file that contains inch values. If I use a factor of 25.4, it should work. Am I correct there?
Peter
Re: mm / inch
PostPosted: Wed May 11, 2022 9:58 pm
by ger21
I think so, but the feedrate will be very slow.
Re: mm / inch
PostPosted: Thu May 12, 2022 5:05 am
by CADdy
Hi Gerry,
you are right, the feedrate should be corrected with an editor bevore milling. I'll test it.
Peter
Re: mm / inch
PostPosted: Tue May 17, 2022 9:58 pm
by CADdy
It only works to a limited extent. The dimensions are okay, but as Gerry already said, the speeds in the G-code have to be adjusted by hand. In addition, neither the tool change point nor the position for the tool measurement are correct due to the factor. You can still work reasonably well with a single tool. But as soon as a tool change is due, you can forget the process. If I didn't have limit switches, the machine would have gone fully into the mechanical stops. It is a pity that G20/G21 are not implemented. Maybe this will still be tackled.
Peter
Re: mm / inch
PostPosted: Wed May 18, 2022 2:02 am
by ger21
The simple workaround is to create two profiles, one for inches, and one for mm's. Shouldn't take more than 10 minutes to set up the second one from a copy of the first.
Re: mm / inch
PostPosted: Wed May 18, 2022 5:00 am
by CADdy
Well, this is a good idea. Thank you Gerry, I'll do it.
Peter
Re: mm / inch
PostPosted: Wed May 18, 2022 9:49 am
by CADdy
I've made a copy from my actual profile and renamed it. But how to change a mm-profile to a inch-profile?
I'm a little stumped at the moment.
Peter
Re: mm / inch
PostPosted: Wed May 18, 2022 11:13 am
by eabrust
You'll update every setting related to movement in your settings for all axes, update position settings for the offsets/softlimits/et. Just converting everthing by the mm to inch conversion.
speeds/velocities: divide by 25.4
steps per unit: multiply by 25.4 (multiplying because the units is in denominator...)
accel rates: divide by 25.4.
etc, etc, all axes, all settings related.
Attached may help, start you off.
Convert mm to inch settings-SCraft.xlsx
(10.95 KiB) Downloaded 265 times
The attached may not be all encompassing of your machine, if you have tool changer positions, etc, you'll have to convert them all as well.
