more new user hiccups...
Postby muzzlitebeer » Tue Apr 26, 2022 8:07 am
Machine is homed. All limits switches operate as expected.
The 'Calibrate' tool in 'SETTINGS' doesn't to anything. I click 'OK' and nothing happens. On any of the axes.
Also, I can jog all axes using 'CONTINUOUS', but if I select 'STEP', nothing happens, no matter how large I make the increments.
muzzlitebeer
Re: more new user hiccups...
Postby dezsoe » Tue Apr 26, 2022 9:46 am
You have to fill the fields on the calibrate form.
Set a feed rate. On program startup the feed rate is low and the step mode uses the set feed rate.
Postby Delco » Tue Apr 26, 2022 10:24 am
dezsoe wrote:. On program startup the feed rate is low and the step mode uses the set feed rate.
Denzoe
Is there a way to change the default start up feed rate and and jog % ?
Delco
Postby dezsoe » Tue Apr 26, 2022 10:56 am
Yes, simply write the fields (and validate) in M99998.
Postby Authority924 » Tue Apr 26, 2022 1:02 pm
Worked for me just perfect, thank you
Authority924
Postby Delco » Tue Apr 26, 2022 10:39 pm
dezsoe wrote:Yes, simply write the fields (and validate) in M99998.
Do you have a example setout and syntax and values ? for Jog% and for Feedrate ? for dummies , I can see nothing in M99998 that relates
Delco
Postby ger21 » Wed Apr 27, 2022 11:50 am
AS3.Setfieldtext(100, 867); // Set Feedrate to 100
AS3.Validatefield(867);
Postby muzzlitebeer » Fri Apr 29, 2022 9:03 am
Hi Ger.
I tried copy/pasting that into M99998 and it still loads with a feedrate of 6.0. Does it matter that I'm in demo mode? My 'connected' computer is in the workshop.
muzzlitebeer
Postby johnsattuk » Fri Apr 29, 2022 10:31 am
I get
CS1502 | in line: 12 | error text: The best overloaded method match for 'UCCNC.AS3interfaceClass.Setfieldtext(string, int)' has some invalid arguments
CS1503 | in line: 12 | error text: Argument 1: cannot convert from 'int' to 'string'
johnsattuk
Postby ger21 » Fri Apr 29, 2022 11:04 am
Sorry, put the feedrate in "".
AS3.Setfieldtext("100", 867); // Set Feedrate to 100
