I had occasion today to experiment with the RUN FROM HERE option after stopping a file midway through the run. Took a few tries but I figured out the system and it worked well.
However on startup of a file I have an M7 command at the beginning. This starts my dust collection and hold down system. An M9 at the end of the file turns these off.
When using the RUN FROM HERE option though the M7 does not take place and I have to enter that command manually before hitting the CYCLE START button.
Is there a way to edit the pop up window that asks what you want to do when hitting the RUN FROM HERE button? Or another way to get the software to activate the M7 command on these restarts? It would be nice if I could add that M7 command along with the spindle startup.
BH
