Calibration os Spindle Speeds UCCNC v VFD
Postby anw » Thu Feb 03, 2022 5:53 pm
Hello,
I hope someone can help.......
Over the last year I have built my own DIY CNC machine so solving problems as they pop up and learning during the process. However I think this one maybe beyond my technical knowledge.
I have just upgraded to a 2.2kw Spindle via a Huanyang VFD. (HY02D223B) 220V 11A. I'm using UCCNC to control my 0-10v break out board,(through a UC100) to provide an analogue voltage signal to VI to control the spindle output.
All works a treat, spindle powers up, down etc using the S command. However, After setting an 'S' requirement in UCCNC or via G code the resultant spindle speed (indicated on the vfd) is a bit slower.
Is this a VFD 'PD' setting or is it a selection in UCCNC?
I have set 24000rpm-down to 3000rpm in UCCNC and measured the voltage (at break out board) and result at the VFD. I have also measured the voltage required at the BoB when the VFD is running at a set speed.
Screenshot 2022-02-03 at 17.46.17.pdf
(160.07 KiB) Downloaded 304 times
Can anyone provide a solution of a little advice as to how I can resolve this.
Thank you.
Andy.
anw
Re: Calibration os Spindle Speeds UCCNC v VFD
Postby ger21 » Thu Feb 03, 2022 11:31 pm
My guess is that it's an issue with your breakout boards speed control.
You might try increasing the PWM Minimum duty % and see if it helps.
Postby anw » Mon Feb 07, 2022 10:59 am
Gerry, Thank you.
I have adjusted this and am now looking at within 3% from 24000 down to 10000. At 9000 and below the margin increases the slower the spindle gets.
Since this looks like a function of using an analogue voltage supply I am very happy with the outcome.
cheers
Andy.
anw
Postby ger21 » Mon Feb 07, 2022 1:43 pm
Again, I think it's an issue with your breakout board. With my UB1 board, the analog voltage was 100% accurate at all RPM.
Users browsing this forum: MSN [Bot] and 28 guests
