G31 didn't respect G1 feed rate (A angular axis)
Postby Doncis » Thu Sep 23, 2021 8:03 pm
It is normal that this code smashes into touch probe with rapid feed?
G1 G94
G31 A90 F90
A axis is rotary (deg/min)
Doncis
Re: G31 didn't respect G1 feed rate (A angular axis)
Postby eabrust » Fri Sep 24, 2021 11:16 am
Hi Doncis,
In the manual for UCCNC, it explains that an axis set to 'rotary' doesn't respect feedrate commands, it follows the other linear axes and is only limited by max velocity. Just uncheck 'axis is rotary' box for that axis, but you can leave 'roll over on 360'. It still behaves like a proper rotary, but now will obey feedrates (deg/min).
When I was adding rotary probing to ProbeIt, took me a little bit of trial error to figure it out also. I put the following in my manual for ProbeIt: NOTE: It is recommended that you have "axis is rotary‟ unchecked in UCCNC, having "roll over on 360‟ is fine. The rotary axis will not respect feed rate commands if "axis is rotary‟ is set, and also you may have issues with direction of rotation as UCCNC always tries to make the shortest distance move when set to rotary.
Postby Doncis » Fri Sep 24, 2021 11:49 am
Thanks, I will check later.
I assume that it exclude feed rate only for display purposes. Imagine you want to cut simple slot only with A axis, with set G1 deg/min feed rate, and boom crash with rapid feed..it should always respect G1..
btw I always use G93 for 4axis.
Doncis
Postby frie » Thu Sep 15, 2022 9:43 pm
Doncis wrote:Thanks, I will check later.
I side with Donics on this.
A feedrate command invoked on a single axis, no matter what X,Y,Z,A,B,C it should be respected and executed, in multi axis moves, whatever the program does, also tricks like not make it a rotary but rollover it a rotary then it obeys:
Common you guys: it is a rotary. Sounds the same as: tell it is a circle then the square can roll.
frie
Postby frie » Thu Sep 15, 2022 10:01 pm
For the record, i just finished my upgrade 4th to 5th axis, this was the first thing i found, (not respecting F commands). I'm still shocked i geuss and find this disturbing and an error programmed into UCCNC.
Same as G53 is not a real work space (but that's off topic)
Choose UCCNC for this over mach 3 because of the windows timer clock, as my current controller only does 4 axis.
Please can somebody tell me if a Gcode on UCCNC is run and the CAM is instructing this code for example:
G0 X0. Y0. Z0. A90 B0.
G1 Z-1.0 F150
G01 B45 F100
It will crash my endmill trying to goto C45 with 6000 units/minute (max velocity as per setup) every time. NOT GOOD!.
frie
Postby TReischl » Thu Mar 28, 2024 6:49 pm
So basically telling the software that it is NOT a rotary axis causes it to work correctly.
I know this because I just did it on my system. I have wasted 2 1/2 days and $400 trying to figure this out.
This is inexcusable, it is now 2024 and this BUG has not been corrected.
TReischl
Postby srracer » Fri Mar 29, 2024 3:59 am
I get the frustrations (I started a thread on this 3 weeks ago) but I don't think it's reasonable to expect:
G1 Fx
to work correctly on a rotary axis. Unless you have somehow defined the radius of the material, there is no way to determine the actual distance over material the tool has travelled. And as best I can tell, there is no G-Code for defining the radius of a part in a rotary axis.
Thus, rotary feedrates really have to be controlled with G93. Unfortunately, that IS a bug right now, but I don't think it's reasonable to expect
G94 G1 Fx
to work with rotary moves.
srracer
Postby Doncis » Sun Mar 31, 2024 10:34 pm
Uncheck rotary axis in axis setup. For simultaneous 4axis milling use G93, and feed rate F MUST be defined in every row.
Doncis
Users browsing this forum: No registered users and 30 guests
