UCCNC 1.2113 - tool probing
Postby CADdy » Tue Aug 17, 2021 7:37 am
Hi all,
I noticed that after probing, the tool is only moved up a bit in Z and then the spindle is set to the original X and Y coordinates. Only then is Z moved all the way up. If the tool is a little longer, it would inevitably collide with the workpiece. Couldn't the sequence be changed so that first Z is brought to safety height? Is this programmed in a macro or hard coded into UCCNC? For better illustration I made a short video: https://youtu.be/_bk632s3ZkM
Or am I completely wrong with my problem and making a fundamental mistake?
Peter
CADdy
Re: UCCNC 1.2113 - tool probing
Postby dezsoe » Tue Aug 17, 2021 9:28 am
On the probe setup page set the Safe Z high enough in machine coordinates and tick the Greater Z is safer in G17.
Postby CADdy » Tue Aug 17, 2021 11:27 am
Hi dezsoe,
dezsoe wrote:On the probe setup page set the Safe Z high enough in machine coordinates and tick the Greater Z is safer in G17.
thank you so much! "tick the Greater Z is safer in G17" was the right tip.
Peter
CADdy
Users browsing this forum: Bing [Bot] and 9 guests
