frequency setting
frequency setting
Postby jonathanmahnken » Fri May 14, 2021 8:04 pm
how do I know which frequency setting to use in thee program
jonathanmahnken
Re: frequency setting
Postby jonathanmahnken » Fri May 14, 2021 10:35 pm
sorry I should have said Kernel speed
jonathanmahnken
Postby cncdrive » Sat May 15, 2021 5:21 am
The kernel frequency is the maxium step frequency the motion controller can output to the driver.
The 1/kernel frequency is the length of the step pulse, so the higher the kernel frequency the shorter the step pulses are.
So, it is important to do not set the kernel frequency too high, because your drive might be unable to read them properly and that could lead to lost steps which means position loss.
Set the kernel frequency the lowest possible for what you need to reach your target speed with your motors.
If software does not allow you to set the steps per times the velocity to higher than the kernel frequency, so you will see if the kernel frequency you setup is too low, because when you will try to apply the velocity value then the software will pull it back to the maximum possible with your kernel frequency.
Postby jonathanmahnken » Sat May 15, 2021 8:30 pm
Thank you. This is exactly what I needed. I currently have the program set to the highest frequency, running gecko 201x drivers which have a built in 10x microstep. Im guessing that I need to dial down the kernel speed to the next lowest setting.
jonathanmahnken
Postby jonathanmahnken » Sat May 15, 2021 8:31 pm
jonathanmahnken
Postby Robertspark » Sun May 16, 2021 7:21 am
https://www.google.com/url?sa=t&source= ... j0xzDQOzJ2
200khz maximum .... but it depends....
if you a running an encoder, you may want more / higher kernel frequency
really you should calculate your maximum rapid velocity for each axis divide it my 60 to give you the velocity per second. then calculate the number of steps per unit. multiply one by the other and it will give you the maximum axis frequency.... this gives you the minimum required kernel frequency
