When I purchased my system upgrade parts from CNC4PC I also bought the Wildhorse Innovations Econo Probe. I'm now trying to get that running in UCCNC for simple, basic Z-axis touch down only. I don't anticipate ever needing the 3D side probing capabilities of this. Now that I see the system I think a simple 1" thick aluminum block as I've had on past machines would have been all I needed for a probe.
I've got the CNC4PC probe control card installed and the probe is connected. Touch the spring loaded button on the probe and all indicators activate in UCCNC and on the probe itself.
I've loaded the probe plugin in UCCNC.
When I use the PROBE button on the UCCNC main screen the Z-axis drops and touches the probe. It then retracts upward and then goes down and touches the probe a second time. Then the Z-axis retracts all the way up and hits the Z-axis limit switch, thus triggering the UCCNC RESET button. No change appears to take place in the Z0 location after doing this.
I've tried typing G31Z0 in the MDI window and this makes the probe go down. However it jams into the spring loaded probe button and does not retract upward.
When I try to use the probe from the TOOLS, PROBE screen I get a MACHINE NOT HOMED error message even after homing the machine from there.
I have read the manual (Information button on the probe screen) and tried setting up the parameters there. Again I can't get anywhere because of the "machine not homed" error message.
At this point I have an hour or two into trying to figure out how this is supposed to work. Can anyone give me the basics that I'm missing ?? Again, all I want to be able to do is touch down to set Z0 on my material thickness.
BH
