On the CONFIGURATION, GENERAL SETTINGS page, at the bottom right, there is a checkbox for MEASURE DWELL IN SECONDS INSTEAD OF MSEC.
If I put a G4 P5000 line in a file, and DO NOT check the box for changing the dwell from milliseconds to seconds, the file pauses for 5 seconds as it should and then continues.
However if I check mark the box for measuring the time in seconds, whether I add a G4 line of code or not, the file hangs up on my M3 spindle start command.
While this seems like a bug I suspect its more likely that as a new user I'm just missing something.
Guidance?
BH
